1 - 7 of 7 Posts
Hi there, I'm trying to decide on a mic pre and like the FireWire Solo. It seems, (from search), there were/are issues getting it to work with REW. Most posts on subject were several months to a year old. Has anyone used this unit successfully with XP OS? I like the 24 bit and firewire capability. PreSonsus firewire seems to have issues as well. Any thoughts appreciated.
FireWire Solo has mic in / and line outs via 1/4" TRS connections. Interconnect diagram 3, shows external pre connection to PC via USB.
firewire feature is useless with REW
So REW will recognize USB but not firewire? M-Audio pre USB seems to work (via search), was asking if anyone had luck with firewire connection, (may purchase MLS software in future). The search I ran for any info on REW / Solo combo turned up a little, but were mostly older posts. Curious as to any success, (driver update / patch etc.), since latest post (7/27/09).
Discussion Starter #5
It has:
total I/O: 6x4
simultaneous I/O: 4x4
24-bit/96kHz audio interface
front-panel microphone in (XLR) with:
• 48V phantom power
• gain control
• clip LED
front-panel guitar input (1/4” TS unbalanced) with:
• gain control
• clip LED
2 line inputs (1/4” TS unbalanced) on rear panel
front-panel switch toggles front/rear inputs
2 line outputs (1/4” TRS balanced)
S/PDIF digital I/O (RCA coax) with 2-channel PCM
digital output also supports pass-through of AC-3/DTS surround-encoded content
stereo headphone output (1/4” TRS)
level control for headphone and analog outs
flexible software-based routing/mixing with near-zero latency monitoring
dual FireWire ports for easy device chaining
FireWire bus-powered (+12VDC power supply included for use with 4-pin FireWire PCs)
ASIO2, WDM, GSIF2, MME and Core Audio compatibility
We do know that REW will not work with firewire connected devices using Mac's, but the assumption is that it would be fine with Windows OS, although I don't remember anyone posting that they were successful.
Discussion Starter #7
Thanks all for the response. I'll probably go with the M-Audio USB, but might just try to catch a cheap, Solo (Firewire), version on e-pray and try it.
1 - 7 of 7 Posts
