1 - 3 of 3 Posts
Hi I have a small bedroom set up with 3 k5s and 2 k4s, i just wanted to know if anyone had ever used these small speakers and if they worked better with a bit of toe in?
My room is about 10ft wide and 13ft long, i would have a play around myself but i have just got out of hospital and cant walk for 8 weeks :(
Thanks for any advice.
Not sure about your particular speakers but the manufacturer (M&K in your case) might be able to guide you with general speaker guidelines.
Some manufacturers recommend toe-in and some do not!
At the end of the day it is your ears and enjoyment that really matter! Experiment, listen and trust your own ears! :T
...Glenn :bigsmile:
1 - 3 of 3 Posts
