Can someone confirm that I have my numbers correct before I start my project.
For the Box.
Height: 790mm
Width: 595mm
Depth: 580mm
Internal 221lt less Port, Bracing and Driver = 200lt
For the slotted Port:
Height: 51mm
Width: 559mm
Length: 923mm
The box will made out of 18mm MDF with a double front baffle.
2nd order high pass filter @ 14hz
And the amp will be:
OAudio subwoofer amplifier
500 watt : OAudio
500W RMS into 4ohms @ 0.3% THD
420W RMS into 4ohms @ 0.05% THD
325W RMS into 8ohms @ 0.01% THD
S/N (A-weighted): 105dB
Lowpass Crossover: 40Hz to 120Hz, 4th order
Parametric EQ: 20Hz to 80Hz, 0 to -12dB, variable Q
Continuous Phase Adjustment
The Manual and User Guide
http://www.oaudio.com/docs/subamp_variouseqsettings.pdf
Please, any help or suggestions would be great.
Thanks in advance.
For the Box.
Height: 790mm
Width: 595mm
Depth: 580mm
Height: 51mm
Width: 559mm
Length: 923mm
500 watt : OAudio
Thanks in advance.
