1 - 7 of 7 Posts
Hello.
I am placing a order for 2 18" Phallus and I was hoping to get some advice as to a what would be the ideal size inclosure to use since my space is limited and would like to go as large as possible. The challenge is that I am also using the boxes to hold up my other speakers on the Left and Right of my screen. This is what I have to work with
MAXIUM
29" Wide
22" High
20" Deep
I was thinking a slotted port on the side as this box will be tucked into the corners of my room firing out into the space. The room is 15'WX7'HX35'L.
I have attached a picture that shows my DIY sitting on top of a pair of Seaton Submersive HP.
I am planing on using it 90% home theater and my mains are running 50HZ and up. The amp I will be using is a Inuke 6000 it has a LP filter but I may just buy the iNUKE6000DSP to have the additional use.
29" Wide
22" High
20" Deep
I could make a larger box but that would turn out more like a 'L' and come under the screen. I would like to get a acoustic transparent screen then the sky is the limit If I was to go sideways it would be 20deepX18 highX64 long without changing my screen.
1 - 7 of 7 Posts
