Status
Not open for further replies.
21 - 40 of 113 Posts
Hate to throw another option in the already very over crowded ring but Kevin will be shipping the new Tempest-X and if I understand correctly it should be available in a couple of months. It should be awesome. :devil: You might have to start a new thread about the Tempest-x box. :R
Matt
Discussion Starter · #22 ·
Acutally, those were my two driver choices :)
It mostly depends on which is cheaper, or if one performs much better than the othe for the extra money. I think I would rather go for a 15" in my room, so my dad doesn't think that it will be really crazy, but that 15 is just as good as the IXL 18 :bigsmile:
Thanks, and I will just go off of what Kevin recommends in the Application Notes for a box size and dimmensions :T May have a few questions on bracing though. I'm anxious to see the new driver model in WinISD...
Have you looked in the classifieds section? There are 4 lightly used Tempest-X's for sale right now I think. Depending on the whole price is a limiting factor thing.
Discussion Starter · #24 ·
Ok, thanks for that.
I think I will wait until the Generation 2 Tempest-X's come out though. Unless they are too expensive, then I will get the one of the ones for sale here. Also, I need to get some surround speakers, so I will just get those now, and hopefully will have enough money saved to still get the Tempest-X or IXL 18.2.2
Thanks for the help
70 pages of advice over 3 forums and you get surrounds instead of a sub.. classic
:rofl:
If you are going to build the sub you could build the surrounds. Have you looked at the kits that GR-Research, Madisound and Parts-Express have available? Some of the kits even have the box.
Matt
:rofl:
Matt
No... can you imagine how long narrowing down a crossover and 2 or 3 drivers would take if one sub took this much :bigsmile:
Discussion Starter · #28 ·
No, lol I'm still getting the sub. Just waiting until the new ones come out to see how much they are. I can still buy the sub too :T
The surrounds are just $75 with shipping and all the parts I needed, so it's not bad at all. It's the "Vifa 2nd Recession Busters Kit" from Madiosound. Includes everything, so I don't have to worry about all of that :T
Thanks for the help everyone
Discussion Starter · #30 ·
You are correct! I will try to start building the box soon, and just make a bottom "plate" where the driver goes the correct cutouts for both the Tempest-X and the IXL 18.2.2.
I don't know, maybe I will save the money that I was planning on spending on the surrounds, and just spend that on the box. About how much do you think the planned box will cost? I have absolutely no idea, so I am hoping you guys will :T
Is there a program that gives you a idea of how the cutouts should be on the wood? Like it shows a diagram of each piece of wood you would need, and placed it so you can see how many sheets you would need? I'm sorry if that confused you guys :) That's the only way I could explain it...
Thanks for the help everybody.
2 Sheets of 3/4 mdf - 50
1 can of spray paint - 4
1 can of spray poly urethane - 9
Wiring posts/screws - 25
1 bottle of titemond III - 9
Discussion Starter · #32 ·
1" inch MDF is REALLY hard to work with!!! It is really heavy. I would use the 3/4 and add the bracing, and double the front baffle. At least that is what I do. Although I made my last box out of Birch but it was a royal pain in the rear, as the sheets of birch are not square!!! The easiest way to I found to finish MDF boxes was rock paint. :bigsmile: :R Although it looks kinda :sick: it is easy to hide mistakes.
Matt
Discussion Starter · #35 ·
OK, so I'm guessing that having the ports around 7 inches away from the bottom of the box will be okay? But, how far away from the driver do they have to be? Since the driver is around 9 3/4th inches tall, wouldn't the ports not fit? Would there be a way that I could 90 degree them near the top and have going out the back of the box? Or, would that create port noise or chuffing?? I really need help on this. I have no clue about it. Sorry for all of those questions again, I just now thought of the ports not fitting...
Thansk for the help everyone.
Seriously.. go with one of DIY's subs either the mael-x or tempest-x and use one of the premade plans in this forum, the avs forum or linked on the DIY cable site. No chance to screw up a box designed for you.
Discussion Starter · #37 ·
I am. But, they don't give you how long to make the ports, just the tune. So, I need to know how I can fit the ports in the box that I had planned. I could go 18x18x55, but then I would need at least two sheets of 19x19x97 mdf. So, my question is, can I put a 90 degree tur in all of the ports?
Thanks
Status
