So what happened? Is it done?
Not yet, but I should be able to get it done, except for the painting, this week. I have not been able to piece together the time to devote to the build.
Here are a couple update pics.
In the second pic you can see that I had to move the location of one of the braces in order to make room for the flared end of the port. Did not take into account the added diameter for the material needed to make the flare. Good thing for dry fits.
Since these pics where taken, the flare of the port end that will be inside the box has been completed and the inside of the port painted black. Figured it would be easier to paint the inside of the port before it is glued into the box. Next is to glue in the open cell foam using some 3M 45 spray on adhesive, install the binding posts, glue on the last couple of sides, around over all edges, and flare the other end of the port.
