1 - 7 of 7 Posts
I a thinking of doing this sealed build:
http://www.hometheatershack.com/forums/exodus-audio/12134-my-sealed-maelstrom-x-build.html
Or a ported sonotube build. If I go the ported route I will need some help. Either way I will use an EP2500. And an Ed EQ.2. It will be used for 90% HT nd 10% music. Here are my questions:
1. How many ft3 does it need to be? Size really is not an issue as long as its not a behemoth.
2. Is 17hz a good point to tune this enclosure at?
3. Can I use one 6" flared port if the tuning is around 17hz?
4. If I use 30" sonotube does it need to be braced at all?
Ported will give you more low end output for a HT application. The ED eQ2 does not work well with pro amps due to not enough voltage. The Reckhorn B1 from CSS would be a better choice.
That depends on how much output you want. How big is the room and is it closed off or open to other areas? Have a look at this build and see if it's too big for you.
http://www.hometheatershack.com/for...dual-maelstom-x-ported-sono-build-thread.html
That will depend on what enclosure size you decide on.
Not with an EP2500. 8 inch is minimum.
No bracing required with a sonotube. Double end caps are required.
I think I will go with a net of 14.2ft3 so it will end up being about 13.5ft3. My room is 16x8x25 with openings to a kitchen and a hallway.
Where should I tune it at?
How do I cut 30 inch circles for the double end caps?
A 30 inch diameter tube won't work. There is not enough space between the end of the port and the back of the sub. A 26 inch tube is as big as you can go. Here are all the dimensions you would need to build a 13.5 cu.ft. tube tuned to 16 hz with a 8 inch diameter port.
Text Line Font Screenshot Parallel
1 - 7 of 7 Posts
