Wow, you do excellent work even with a cold!
I have never lined the walls with egg crate foam for a sealed enclosure, so far I have just used poly fill from wal-mart. For this massive enclosure those cheap pillows from wall-mart will probably be a better idea as it would not be as messy.
As far as bracing it looks good to me so far, Kevin would have a better idea if magnet bracing is advisable but I personally never do it even with really heavy magnet drivers. I would definitely double up on the front faceplate were the driver mounts, you might even consider 3 layers.
This is gonna be a monster, can't wait until you fire this beast up:flex:
