Martin Logan Vantage Electrostatic Speakers in Dark Cherry & Stage Center Channel
Brand New Replacement Panels (still in box) which cost $2000 from Martin Logan
Combined cost was over $10,000 and the replacement panels are $2000 from Martin Logan which means I have around $12,000 all in on this front stage.
Note: Speakers are now in Knoxville, Tennessee
Specs:
"Based on the state-of-the-art Summit™ loudspeaker, Vantage offers unprecedented performance for its size and price. Key to this achievement is our PoweredForce™ active woofer technology, which generates deep, articulate, dynamic bass from an astonishingly compact cabinet. An XStat™ electrostatic panel handles the midrange up, delivering the smooth, pristinely detailed, and richly ambient sound that is the hallmark of MartinLogan speakers. No ordinary speaker comes close."
Frequency Response
34--23,000 Hz ±3dB
Horizontal Dispersion
30°
Vertical Dispersion
40" (102cm) line source
High Frequency Transducer
XStat™ CLS™ electrostatic transducer
» Panel Dimensions
40" × 9.3" (102 × 24cm)
» Radiating Area
372 in2 (2,448 cm2)
Low Frequency Transducer
8" (20.3cm) cast basket, high excursion, aluminum cone with extended throw drive assembly, non-resonance asymmetrical chamber format, bass reflex
Amplifier
Woofer: 200 watts/channel (4 ohms)
Sensitivity
92 dB/2.83 volts/meter
Impedance
4 Ohms, 1 at 20kHz. Compatible with 4, 6, or 8 Ohm rated amplifiers.
Recommended Amplifier Power
20‒500 watts per channel
Crossover Frequency
400Hz
Components
Custom-wound audio transformer, air core coils, polypropylene capacitors
Audio Controls
±10dB at 35Hz
Inputs
Custom 5-way bi-wire binding posts
Power Draw
Idle: 8W/channel
Max: 140W/channel
Weight
52 lbs. (23.6 kg)
Dimensions
57" × 10.7" × 16.25"
(144.7cm × 27.3cm × 41.3cm)
Stage Center Channel:
"Ultimate-Performance Electrostatic Center Speaker
Designed primarily to serve as the center in a home theater incorporating other XStat™-based MartinLogan electrostatic speakers, Stage™ is versatile enough to handle left-, right-, and surround-channel duties as well. Its dual 6.5-inch aluminum-cone woofers and advanced Vojtko™ crossover seamlessly integrate a solid bass foundation with the astonishingly transparent, detailed midrange and treble produced by its XStat panel. A single-pivot bracket/stand facilitates set-top, shelf, on-wall, or on-floor placement."
Frequency Response
69--22,000 Hz ±3dB
30°
1" (2.5cm) neodymium soft dome
Mid Frequency Transducer
Patented CLS™ XStat™ electrostatic transducer
» Panel Dimensions
7.5" × 18" (19.1 × 45.7cm)
» Radiating Area
135 in2 (873 cm2)
Two 6.5" (16.5 cm) cast basket, aluminum cone with extended throw driver assembly, non-resonant asymmetrical chamber format
Sensitivity
90 dB/2.83 volts/meter
Impedance
Nominal: 4 Ohms
Minmum: 2.9 Ohms . Compatible with 4, 6, or 8 Ohm rated amplifiers.
Crossover Frequency
450, 2700 Hz
Components
Custom-wound toroidal audio transformer, air core coils, polypropylene capacitors
Inputs
Custom 5-way binding posts
Weight
39 lbs. (17.7 kg)
Dimensions (without mounting bracket/stand)
9" × 34.6" × 10.3"
(22.7cm × 87.9cm × 26.1cm)
Dimensions (mounting bracket/stand beneath speaker)
12" × 34.6" × 10.3"
(30.4cm × 87.9cm × 26.1cm)
I spent around $10,000 for the Vantages and Stage combined and this is not even including the $2000 for the replacement panels. I ordered the panels thinking they needing replacing only to find out it was my amplifier behind the lack of response. Regardless, I ended up keeping them. Speakers still sound great and have zero issues achieving more than satisfactory SPL's when running Audyssey XT32 and in general operation.
The Stage is simply a fantastic Center Channel and is in very good shape. Truthfully, if this package was placed on Audiogon or Ebay, I am quite confident they would sell for thousands more, but without boxes and the fragility of ESL's, I do insist on local sales only. Or perhaps within 100 miles could meet up.
Please feel free to call (615-497-6597, text, or email with any questions
Specs:
Frequency Response
34--23,000 Hz ±3dB
30°
Vertical Dispersion
» Panel Dimensions
» Radiating Area
372 in2 (2,448 cm2)
Amplifier
Sensitivity
Impedance
Crossover Frequency
400Hz
Components
Audio Controls
±10dB at 35Hz
Inputs
Power Draw
Idle: 8W/channel
Max: 140W/channel
Weight
52 lbs. (23.6 kg)
Dimensions
Frequency Response
69--22,000 Hz ±3dB
30°
» Panel Dimensions
» Radiating Area
135 in2 (873 cm2)
Sensitivity
Impedance
Nominal: 4 Ohms
Crossover Frequency
450, 2700 Hz
Components
Inputs
Weight
39 lbs. (17.7 kg)
9" × 34.6" × 10.3"
12" × 34.6" × 10.3"
