1 - 4 of 4 Posts
I'm on the fence with my crossover selection (old Pioneer Elite VSX-43TX soon to be replaced with a new SC-71). below is list of the speakers in a 5.1 system
Speakers
Front's - Infinty RSb's
Introduced: 1978
Dimensions: 63 x 35 x 25 cm
Bass: 1 x 25 cm
Mids: 1 x 12 cm
Highs: 1 x EMIT (Yup, still kick'n with the original diaphragms)
Enclosure Type: Acoustic Suspension
Suggested for amplifiers with: 35-200 Watts per channel
Frequency range: 45 Hz - 32 kHz
Crossover frequencies: 600 Hz, 4000 Hz
Suggested price (Then - pair): $580
Woofers rehung in Late '90's and in good shape.
http://www.infinity-classics.de/mode...ence-klein.htm
Center - Infinity Video-1
Frequency Response: 58 Hz - 20 kHz +-3dB
Sensitivity: 89 dB @ 2.87 volts, 1 meter
Power Rating: Use w/amps rated between 5 - 100 watts RMS for Center Channel
Crossover Frequency: 4.5 kHz
Nominal Impedance: 8 ohms
Drivers: Dual 5-1/2" Polyproplene woofers, 1/2" Polycarbonate tweeter.
Magnetically shielded for video applications. (An old spec dating back to CRT's for you youngsters)
Dimensions: 18-1/4" wide, 7" high, 6" deep
Surrounds - Infinity SM-65
Power Rating: 10-100 Watts
Freq Response: 78Hz-25kHz +/- 3db
Crossover: 4.5 kHz
Efficiency: 94 db SPL, 1 watt/1 Meter
Impedance: Compatible with 4 to 8 Ohms
Drivers: 6-1/2" Polypropylene Coated Woofer, 3/4" High Output Polycell Tweeter
Dimensions: 8" wide x 13-1/4" High x 7-1/2" Deep
Rear Ported
http://www.infinity-classics.de/tech...15-125-155.pdf
Read more: http://www.hometheatershack.com/forums/rew-forum/72236-noob-new-setup-soon.html#ixzz2poaFEhLa
The question is can I cross the sub @ 80 Hz considering the fronts and center low end (45 & 58 Hz respectfully) even though that is crowding the low end response of the surrounds @ 78 Hz? I don't have a REW sample as yet and I'm aware that the results may make the question mute.
80Hz. may be a bit low with those specs..I would be more inclined to make your xover at 100Hz..and set your speakers to "small"..
Thanks for the reply. Just thought I might get away with 80hz on the surr's. I've read the surr's don't necessarily get as much of the low end.
Generally your xover frequency should be approx. double the lowest frequency of you front speakers..
In your case the centre speaker at 58Hz. would require a xover at 100Hz.
Since there is no separate xover adjustment for the surrounds with MCACC, it's not so critical..
My surrounds are 75Hz - 22KHz. and my fronts are 30Hz.- 20KHz.and I use an 80Hz. xover..
Best thing to do is to try both and see which one appeals to you..It's not set in concrete..
1 - 4 of 4 Posts
