1 - 20 of 20 Posts
I started with a MC240 that had been neglected for years in an old shed.
Discussion Starter #2
This poor things had seen better days.
The first thing was to give it a really good cleaning. Doesn't look so bad on the underside now.
Discussion Starter #4
The top was pretty bad, so I masked it off and bead blasted it.
Discussion Starter #5
Then some primer.
Discussion Starter #6
Followed by some more masking and then some burgundy paint.
Discussion Starter #7
Now to update the electronics. Replaced the electrolytics and bubble bee caps.
Discussion Starter #8
Next the selenium rectifier had to go. Easy enough with a resistor and diode.
Discussion Starter #9
A little mod for convenience. I moved the fuse to the inside and installed a push button power switch.
Discussion Starter #10
Ready for another 50 years of service. The tubes don't glow that bright. It is a result of a long exposure shot.
Nice work. The MC240 is a classic and a wonderful amplifier. It was designed for horns. Hook it up to some old JBLs, Altecs or EVs and it will sing. :)
I absolutley love watching your builds/mods. You do great work. I am curious how you cleaned it up. Did you use a liquid medium?
Discussion Starter #17
I use it to drive a pair of 1968 JBL C50 Olympus speakers with custom JBL 2397 horns.
Discussion Starter #18
I used spray flux remover to clean the dirt out.
Beauty job. I've always liked the look of that amp. The 3 massive transformers always impress. The JBL's are gorgeous as well.
1 - 20 of 20 Posts
