1 - 3 of 3 Posts
Hello, welcome to the forum.
Tell me about your equipment and your room.
Which AVR (or processor/amplifier) do you have ?
What speakers do you have ?
Do you have a subwoofer ?
How big is your room ?
How far away from the speakers do you sit ?
Is the floor tile, wood, carpet ?
If the floor is tile or wood do you have a rug ?
Is your furniture large and stuffed or simple wood, wicker, metal ?
Are the walls bare plaster and glass, or do you have book cases or heavy drapes ?
When you say mid-range do you mean voices and dialogue or do you mean guitars ?
What is it that you are trying to fix ?
Whats your budget?
If you want something truly world class, I suggest Danley, Seaton, Quested.
Danley are more transparent than the other two suggested.
1 - 3 of 3 Posts
