Minidsp Dirac Live mutichannel
4621 Views 22 Replies 6 Participants Last post by  AudiocRaver
Hi I have system that consists of a Yamaha Z9 http://usa.yamaha.com/products/audio-visual/hifi-components/stereo-receivers/rx-z9_black__u/ + Denon 3910 http://assets.denon.com/documentmaster/us/dvd3910_ownersmanual.pdf
Can someone please suggest a Minidsp Dirac Live multichannel unit that I could purchase.
Please keep in mind I listen to a lot 2 channel
Thanks in advance
1 - 20 of 23 Posts
Thanks in advance
  • NanoAVR DL before the Denon: no additional AD or DA conversions, can only process LPCM, 48 kHz sample rate limit (up to 192k is downsampled to 48k), 2 HDMI inputs (1.2?, 1.3? not 2.0)
  • DDRC88A after the Denon: 96 kHz sample rate limit (up to 192k is downsampled to 96k), additional AD and DA conversions, no limit on types of input data & processing into the Denon, no limit on HDMI inputs
Thanks Wayne my inputs & outputs are limited on both the Yamaha Z9 receiver and Denon 3910 DVD player, no HDMI.
Any ideas for connection, currently using ilink
Thanks again
Thanks again
Oops, I see I got Denon and Yamaha mixed up in my answer. And I assumed HDMI in the Yamaha. Imagine my surprise!
Lets try again:
I believe I saw pre outs and amp inputs on the back of the Yamaha, right? So you are back to the DDRC88A if you want Dirac on a surround system. If your only concern was 2 ch Dirac, you could use the DDRC-22D on the input side, 96 kHz sample rate limit (see previous explanation), but that stops all non-LPCM processing.
Sorry about the previous hurried answer, it made no sense at all!
Thanks Wayne, no worries
Yes the Yamaha Z9 has pre-out-inputs for the front two and centre but no rears.
Any other ideas?
Thanks again
I think I would go with a DDRC - 22 D on the input side for 2.0 or 2.1 application and possibly for your red left and right in a surround configuration, not worry about the rest of the speakers, use delay settings to match them all up in time. Or go with fewer surround speakers and the DDRC88A on the output side. You could always add an external amplification for that last couple of speakers.
DDRC - 22 D for 2 channel DIRAC LIVE
If it were my system , I would consider 2 options
A. a multi channel amp like the EMOTIVA XPA5 ($899) add XPA2 (for 7.x system @ $720) use the pre-outs of the Yamaha > DDRC-88A > Emotiva amps.:spend:
B. a new HDMI receiver - a more modest investment :clap:
I assume that you have, at least, considered a new receiver since you have the money to put down on a MiniDSP unit...:whistling:
You ONLY LIVE ONCE - Go for the Emotivas and the DDRC88A !!
I gotta admit, a Home Theater without HDMI is hard to picture. That sounds like the right first step to me.
Since the Z9 has pre-amp outputs and amp inputs for the L/R/C channels, he’d only need a two or four channel amp (depending on the number of surround channels he’s using), not a full-blown 7-channel model.
My only concern with the DDRC-88 is that miniDSP does not publish a noise spec for it, as a quiet noise floor is critical for an outboard equalizer. Have you or someone you know used one?
Are you unhappy with your AntiMode equalizer?
They do in the product brief, 105 dB SNR. Linked here.
Hi guys thank you for your advice
The Z9 is a stayer
Maybe look at the DDRC-88A use it for the fronts + centre.
The Antimode EQ is good but think I could do better. Option would be to get the DDRC - 22A for the front two and use the Antimode for the centre?
Thanks again
Hi Wayne you say 2.1, how do get this with the DDRC-22D, hook up?
Might be missing something here.
Thanks again
Thanks again
I was assuming the DDRC-22D on the input side of an AVR, and with the AVR providing bass management.
Some of us feel that putting BM after the EQ is a big compromise.
Indeed, & I believe I understand the reasons for saying that. As a practical matter, and with some thoughtful use of DL individual target curves, a pretty satisfactory result can be had.
Just curious; why is this a concern? I haven't seen this mentioned before.
My understanding is that with BM before the Dirac Live, then DL is being applied to individual driver amps/channels, giving the best control and most predictable result. With DL before BM, DL's affect on low frequencies is not as clear cut, affecting both of the channels that feed into the BM. If designing or building a new "idealized" system, BM before DL is probably the ideal to shoot for.
Agreed.
Hi guys thank you
Maybe the DDRC 22A would be better?
Or maybe get the DDRC 88A? for any updates in the future for gear?
Do I have to use all the channels in the 88A?
Thanks you
1 - 20 of 23 Posts
