im thinking of buying one for my sub im building. do you have to buy the software or does it come with it? and also was shipping expensive i see on their website they come from china
You have to buy a plug-in. Otherwise you can't do anything with the miniDSP.im thinking of buying one for my sub im building. do you have to buy the software or does it come with it? and also was shipping expensive i see on their website they come from china
Kit is the guts only, no enclosure. Enclosure gives some protection against dust and makes it easier to pick up and move around (without fear of touching internals. AFAIK all units are configurable via jumper between Rev A and Rev B.Alright good to know. And what is the difference between the "kit" version and the "in the box" version? the kit is $99 and the in the box is $125 is the only difference the fancy box/shell it comes in. what am i losing if i bought the kit version? and what "Rev" is the kit version. the box version come in RevA (<.9v rms) or RevB (2v rms) i need RevB. Do you just program the kit version to what Rev you need?
As Far As I Know.Alright awsome thank you for all the info ill be getting one. and also what does AFAIK mean
Yes...![]()
I am a bit confused by the labeling for the MiniDSP Output XLR side. Shouldn't S be connected to Shield?
Thanks Jeff, appreciate it.shouldn't be a problem
