The miniDSP DDRC-22 series stereo processors will not degrade your sound. They have 24/96 resolution, and can be inserted between amp and preamp/source (analog version) or DAC and preamp/amp(digital version). If you don't like the idea of digitizing your vinyl while you listen, you can always bypass the miniDSP on its remote. If you get the digital-only version, you can avoid two conversions by feeding it the digital output from your DAC.
Sent from my iPad using HTShack
