monomer, thanks for the reply, I grabbed the new file.
4 decimal places on the sensitivity seems a bit over done like they should have rounded it but I'm nitpicking.
I'm just starting to learn REW and thought the sound card cal was necessary to get an accurate test signal output from the computer, especially if I have to use the analog out, at least the instructions from what I can see tell you that you need to do so, but I haven't read through all of them yet. Also, I'm playing around with several scenarios and I'll need analog and digital connections so I started there. Part of the problem I'm seeing with the USB mic now that I have it is the cable length limitation, my HTPC is cabled through the wall to the next room where my HT is set up, I'm beginning to wish I had gone the more expensive route of a phantom powered mic with a conventional cable, oh well.
Finding out that the cal files had changed again through this forum is a testament to how good this forum is but not so much for MiniDSP, it would have been nice to see an Email from them announcing the change.
