1 - 4 of 4 Posts
I have a Mitsubishi WS55807 that one day simply did not turn on. It smelled like something electrical had burned from the back of the TV. I unplugged the TV for a few minutes and them plugged back in and it turned on with no problems. I tried shutting off and turning on a few more times, and sometimes it would turn on and sometimes not. Eventually after about 8 times turning on and off it wold not come back on anymore, and again a burning smell. I opened the back of the set and removed the circuit board and found pico fuse F9A06 blown. I carefully looked over (and smelled over) the entire board but could not locate any visible signs of damage. I went ahead and replaced the F9A06 7A pico fuse and the TV turned on without any problems. I shut the TV off and left the TV plugged in overnight and turned on in the morning without any problems. After work I came home and got the burn smell again when I walked up to the TV, and again the TV would not turn on (no green light, just nothing). I unplugged for a few minutes and turned on and the TV works great. Is see F9A06 is in the Standby Supply Regulator circuit ( I have a service manual), any ideas of what is causing the TV to be so intermittent in turning on?
DrJones
Plain ole user
These sets were notorious for coolant leaks from the CRTs. Look very carefully for corroded spots on the boards or wet spots.
I did see some wet spots on the multi-component processor (IC2V00), so I cleaned and scrubbed with a good non-residual circuit board cleaner. The TV has been working great for about 4 months now and then decided shut off again today. Same symptoms, no green light, however this time I cannot seem to revive the TV by simply plugging and unplugging. I did a little troubleshooting and temporarily shorted the collector and emitter on transistor Q9A51 (which is the transistor hooked-up to the power button on the front panel) and the TV "turned on", but with no high voltage for the CRTs, but maybe some audio voltage because I could hear the speakers "pop". I performed a few voltage checks on the output of the Switching Supply Regulator (while temporarily shorting the emitter/collector) and see some strange voltages. I ordered a new Switching Supply Regulator from one of your recommended vendors, so I will try that when it arrives. I will post if it doesn't or does work. As always, your comments/suggestions are welcome.
Discussion Starter #4
An update - A few months later I trashed the Mitsubishi and purchased a Panasonic TC-P65ST60 65" plasma and have been happy ever since :D
1 - 4 of 4 Posts
