1 - 5 of 5 Posts
I finally have a good big screen a dlp mits 60737. how can I hook up my pc? it only has hdmi, rgb. any easy ideas or that are cheap? my pc(laptop) only does not have hdmi or s video output. maybe I should find a new laptop.
as always this forum has so much help and good advice.
Plain ole user
VGA out to RGB in. You will be limited to 649x480 however, which will not be pretty.
HDMI to this set will be variable depending on the video card flexibility. The set was not really designed to be great with computer output. But it can work with the right card or computer.
so I can get an adapter for the rgb? cool, do you know if they are expensive? oh, I will just go google them. thanks, sir. Now I cant wait for the 3D. Have a great day.
1 - 5 of 5 Posts
