1 - 2 of 2 Posts
G
I'm having a problem with my Mitsubishi 46809.
The below picture shows the issue. I won't even try to describe it as the picture shows the issue. I do not know if this is a sync issue or something else.
Here is the normal view:
The issue started about two weeks ago and last weekend we lost the blue input on the 1080i input. The DVD 480p input was not affected. I took the back of the TV off and pulled out the PCB Terminal and looked at the Blue input for the 1080i. The pad was lifted so I soldered a wire from the blue post to the PC board. I fixed another one like it that was not completely broken.
The issue in the first pick happens intermittently and it does affect all the inputs.
Anyone know what the issue is called or where to start to figure out how to fix it?
Plain ole user
1 - 2 of 2 Posts
