My five year old Mitsu will not power up...The timer light blinks for about 5 seconds and then goes away. Pressing "Device" and "Menu" yields an error conde 2-3, "Loss of Deflection" per the user manual. Prior to dying, it had a similar episode; I had disconnected the TV for a long weekend out of home, and when returned and connect it, it won't start. I unplugged it for several minutes and connected it back and then it powered up. A few weeks later it finally died.
One point that may or may not be relevant is that I had notice for the last several months , in one of the inputs, a sort of a greenish tone in one of the screen edges. In another input, I tried the advanced convergence that improve this. I was not able to try it in the other input.
This is my third Mitsu HD RPTV set in about nine years. The first two were under extended warranty, but this one is not.
I am trying to see if I can get any DYI recommendations that I would be able to implement in order to save this set. The repair shops would normally replaced the board, and are not willing to troubleshoot and repair the board. Replacing a board will be very expensive, if you are lucky to find them.
Any help is appreciatted.:help:
