1 - 4 of 4 Posts
My Mitsubishi 42 tv wt-42311 shut off today while watching it, and evey time I try to turn it on the green led comes on and then shuts right off. I've had it for over eight years and a 9 mths ago the buttons on the panel stop working, so I can only turn it on with remote control. I try to get a error code by pushing the menu and input button at the same time and get no flasshing codes, but like i said the panel has not been working. Any ideas or help please.
Plain ole user
You have to fix the control panel to pull the diagnostic code.
Plain ole user
We have vendor listings that have parts distributors, you can get the parts from Mitsubishi, or you can look in the stickies in the DIY Repair areas and there are some vendors listed.
You likely need the switches or the entire control panel. I would get them from Mitsubishi if you are not familiar with matching and buying these kinds of parts.
1 - 4 of 4 Posts
