1 - 3 of 3 Posts
I have a Mitsubishi WD-62628 DLP tv. I would like to know if anyone knows how to interpret the display when you key in the "MENU 2470" on the remote to display the duration life of lamp. I have replaced the lamp twice during the life of the set. It would be informative as how to interpret this and not rely only on recollection of subjective appearance of brightnes of display
Plain ole user
If I recall correctly the early DLP sets had a rolling display of recent times since reset. Some later models just had a total time since reset. ONe would need to refer to the service literature to know for sure.
What does your display look like?
Found out after Google search that the first set of numbers represent total hours and next set are hours to date. Thanks for responding.
1 - 3 of 3 Posts
