[img]http://www.hometheatershack.com/gallery/file.php?n=3071[/img]
Mitsubishi HC3800 DLP Home Theater ProjectorSpecifications
Imaging Technology: 0.65" 1-Chip DMD, 12deg.LVDS, DDP3021
Brightness/Lumens: 1300 ANSI Lumens
Native Resolution: 1920 x 1080
Maximum Resolution: 1920 x 1200
Viewable Size: 50-300 inches
Contrast Ratio: 4,000 : 1 (on/off)
Color Wheel: 6-segment (RGBRGB)
Lens Throw Ratio: 1.38 - 2.06
Zoom & Focus Adjustment: Manual Focus & Zoom Lens (Zoom Ratio 1.5:1)
Horizontal Frequency: 15-80 kHz
Vertical Scan Rate: 50-85 Hz
Inputs: mini D-sub X1, RCA X1, S-Video X1, Component RCAX3, HDMI X1
Lamp Life: 5000 hours (low mode)
Noise Level: 31dB (standard mode) - 25dB (low mode)
MSRP: $1495
True reproduction of the digital source with the latest DLPTM chip
The HC3800 high definition projector features a new digital micromirror device (DMD) that enables smooth, true reproduction into finely detailed images with no noise or deterioration. Densely embedded micromirrors improve the aperture ratio of the latest innovative 0.65 Digital Light Processing (DLPTM) chip, greatly reducing light fusion producing amazing 1080p HD images.
Enhanced brightness, contrast and image depth for amazing HD projection
With the HC3800 you can now transform your living room that can projection high definition broadcasting and Blu-ray sources. A fixed iris delivers 1300lm of brightness and 4000:1 native contrast for amazing brightness and contrast. The HC3800 also includes a newly developed Diamond Lens. This new Diamond Lens is a high performance 1.5 HD zoom lens that provides exquisite focus and image depth for greater installation flexibility and ultra-sharp picture performance.
Lifelike colors and gradation make even mid-range colors pop
The HC3800 take color and gradation to a new level of quality. A six-segment color wheel, new color processing algorithm, BrilliantColorTM, and other innovations enable dazzling reproduction even with mid-range colors. Colors can be adjusted individually through the built-in color management function.
Features
Native 1080p - High definition 1080p resolution for amazing picture quality
HDMI connectivity - Includes HDMI v1.3 input. Allows for a true digital connection for easy connections to your HD equipment.
Anamorphic Mode Support - Includes Anamorphic Mode 1 and Mode 2 support for your viewing enjoyment and convenience
Color Management - Our new color management feature allows users to adjust images to their color preferences. Red, green, blue, cyan, magenta and yellow can each be adjusted individually with out affecting the color quality of other colors.
Diamond Lens - The 4-cluster, 13-piece all-glass lens provides excellent focusing performance with 1.5x magnification of high-definition images.
Ultra-Quiet Noise Level - Amazing low 25dBA noise level (low mode), so you can sit back and enjoy your home theater picture instead of any distracting equipment noise level.
RS232 support - Convenient compatibility with 3rd party control devices
Top Access Lamp - Users can replace lamp with out taking down the projector if ceiling mounted. This design simplifies lamp replacements without turning the projector around or over when mounted on the ceiling or resting on a shelf.
Long Lamp Life - An amazing lamp life estimated to last up to 5000hrs. Provides owner with hours of home cinema watching enjoyment.
Projector Central Review
Art's Review at Projector Reviews
Calculator Pro
Product Webpage
