1 - 3 of 3 Posts
G
Hi, we have a Mitsubishi HD1080 and no remote, yesterday my teen hooked up a cheap game joystick to it and it lost the programming, I was reseting the programming when she came up and started pushing the front buttons, at the same time that I was scrolling and it locked on "lock the front buttons". Help any ideas? Isn't there a ctrl, alt, delete type situation that I can reset? Of course, I unplugged the TV hoping that would do it.... Now it just won't turn on, the green indicator light does flash the 1 - 2 series that was mentioned in another thread... by pressing the two buttons suggested, and of course, I have tried doing that with many other combinations... I'm also looking into ordering the remote from the site that you mentioned as well.:surrender:
Plain ole user
Front panel lock can be removed by holding the menu button for 10 seconds on some models.
Please post the model number when you have a problem. Also, "the site that you mentioned" really gives no info. I have likely mentioned dozens of web sites. Original Mitsubishi parts are generally only avaialable from Mits directly, so others might want to know if you have some other info.
1 - 3 of 3 Posts
