1 - 2 of 2 Posts
There is a manual of how the commands and how to use the rs-232C interface. are there applications for it on a DLP set for instance? Has anyone used it? I see some things for projectors, and maybe that makes sense if already attached to a laptop, but even then what is the usage?
· Plain ole user
They are typically used in home automation systems, like with Crestron systems. It avoids the need for IR control and in some cases gives more access.
1 - 2 of 2 Posts
