yes on my set it calls it "con geo", I also went through "con"vergence set as well. Actually I played with every adjustment allowed in the service menus, as well as the consumer menus, but nothing straightens the green hourglass. I put everything back to original settings after testing. I was really hoping that it would be a setting in there, but it appears not. So I can only guess that one of the filtering capacitors is out of spec. As i said before, when I change the ew pincusion, I can move the blue and red into the same hourglass shape if I want, which I suppose would make convergence work, but that's not a fix, as the image would be distorted on either side. the center of the grid looks goodin the center 1/3rd of the screen. It's just the left and right sides that curve in on green channel. The only settings i didnt play with were the sap/audio settings, and the pip settings, and the high voltage adjustment.
