Does anyone know the problem as i have read on here and other sites that it could be the pip board {plug in type to main board } Causeing this ?Well i replaced the pip board with 3 known working boards same problem also i replaced the Vert Ic 451 Still the same. I read on here that there is a way to bypass the pip board These are the # on board Front 935D414 #5070560 on back # E211a29101 .This is called the DBF. Anyway there was a post to Bypass by putting 10uf50v caps under main board from pin 5 to 11 and 9 to 7 Well i do have the service manual . can not find the pins as the pip booard has 7 pins
3 Da 4 Db so that rules that out Anyway does anyone know were the pins are at or how to fix this problem as this is a very common problem. Also i swaped out a GOOD known tested signal board from another same model and still the same.please help very frustrated Any sugestions im all ears thanks Darren
