1 - 9 of 9 Posts
I have a Mitsubishi WS 55413 and am trying to remove the PCB on the right. I have it all unhooked except for the white wire attached to the flyback transformer. It has a rubber collar around where the wire comes into the Flyback and it doesn't pop off with a firm pull. I don't want to just yank on it for obvious reasons. My question is how do you disconnect it, so you can get the board out? Will it unplug if I pull hard enough or do I have to cut the wire and solder it back together when I'm done working on the board? Thanks in advance for any help offered.
No result yet, Mechman. I've resisted the temptation to pull, hoping to get the answer from someone with more experience. Given what I know, that should be a pretty big pool! Hahahaha
Plain ole user
Your post has been moved to a more appropriate location to make information easier to find and to make it more likely that others who are interested will find your post.
Plain ole user
It may not come out. I don't recall ever having to change a FBT in one of those. Why do you need to remove it? Can you not remove it from the CRT board?
Plain ole user
There is no need to pull the board in most cases. Th whole chassis just slides out.
Discussion Starter #8
I get that part, but if you don't pull the board, how can you desolder the bad parts and resolder the new?
Plain ole user
Take the chassis out completely, turn it on its side, and you can get to all but a few solder joints that are behind the supports on the frame. You can even run it to test with the chassis out of the set.
1 - 9 of 9 Posts
