1 - 2 of 2 Posts
We have a rear projection 65" Mitsubishi that will not turn on.. When we press the power button the green light comes on for a couple of seconds and then goes off. We tried unplugging it and plugging it back in to no avail.. We tried the pressing menu and input and got two green flashes.. Does anyone know what this means?? Is it worth fixing or should we be out shopping for a new set?
Thanks so much!
Colleen
Plain ole user
The flashing LED gives a 2 digit code, so you likely have 2-2 error. Most common is a convergence failure. Read the first ten posts of the convergence repair sticky in the DIY forum very carefully. I would call around to the local servicers and ask about repairs of this sort and see what they charge. If the set is still bright and focuses well, these sets can look very good when properly calibrated and I would fix it if the cost seems reasonable.
1 - 2 of 2 Posts
