1 - 3 of 3 Posts
Replaced 2 convergence chip and one pico fuse and it blew again the pico fuse tv wont stay on, should we replace resisters or don't know day 4 into athis, also it had a blinking light error code 2-2 so that is why we changed out the convergence and only one pico fuse was blown, now installed the pico fuse and it blew again, what is causing this
Plain ole user
When a fuse blows it is usually because a chip is shorted. If a new chip shorts it is either defective or you missed something. I would test the resistors and pull both chips, replace the fuse, and check the power supplies at the chips. You can also have bad caps in the power supplies in these sets than can cause problems, but usually, if the chips fail right away, it is a bad resistor or one supply is missing.
Read the first ten posts here if you have not:
http://www.hometheatershack.com/forums/diy-repair-maintenance/5600-crt-based-rptv-convergence-repairs.html
1 - 3 of 3 Posts
