Hi,
I am working on a WT-42311 and it has an error 21 (X-Ray Protect circuit) code.
I was wondering what x-ray protect circuit is?
I am fairly knowledgeable in repair of electronics but I have worked on few tv's and none with something labeled x-ray protect.
Just wondering what it is, hoping that with more knowledge I can do more troubleshooting.
Thanks for any advise.
Plain ole user
Are you sure that the code is not 1-2 instead of 2-1?
x-protect circuitry shuts the set down if there is a condition that could lead to excessive high voltage. If you are not familiar with troubleshooting high voltage circuits I suggest leaving this to a professional.
I am sure that it is 2-1.
Two flashes half second pause then one flash then two second pause then repeat.
It shuts the set down if there is high voltage in what circuit/area?
Plain ole user
CRT based television uses high voltage on the anode of about 30kV. If something happens that could allow that to rise above normal, you get a 2-1 code and shutdown. Again, if you are not familiar with troubleshooting high voltage in CRT based television, it is best to leave this alone.
So this shuts down the set if the voltage coming from the flyback rises to a value above what is set as acceptable?
Plain ole user
No, it shuts down if the sample of the high voltage output circuit rises above a reference voltage indicating that the HV output may go too high. It also shuts down for a number of other reasons, but a 2-1 code indicates that there is a problem in this area. The source of the problem could be many components.
