1 - 3 of 3 Posts
I've searched this forum for an answer... sorry if this is a repeat.
Very simple: When I turn on the WT-46807 the green power light is on for about a second, then the TV clicks off. It does this whether I try to use the remote or the TV power button (below the screen).
I did a little digging and found that I can get an error code (flashing power light code) if I hold down the Menu and Input buttons. What I got was two flashes, a pause, then one flash.
Thank you in advance for your help.
Plain ole user
Posted via Mobile Device
Plain ole user
IIRC 2-1 is a high voltage protect error. Not a diy job unless you can troubleshoot tv high voltage circuits.
1 - 3 of 3 Posts
