I have some black MLV from another project and am thinking of using it on my ceiling instead of paint. Does anyone have experience with how this looks? I know the seams will be touchy, but with all that light absorbtion will it matter? Also, will I have to use more screws in the gg layer of drywall to support the extra weight of the MLV? I also have some MLV with closed cell foam backing. Would this work better or worse than plain MLV? By "work" I mean will it improve STL somewhat in the room above, assuming I've done everything I can to isolate/decouple/add mass/deflank?
I've always assumed MLV should "droop" to work best. For example, by securing it loosely between battens. What about securing it with green glue?
Is MLV ancient history in the age of Green Glue (I used to call this stuff contact cement because it was a gummy mess used to adhere Formica to MDF for countertops), or does MLV still have some fans? Obviously the cost is outrageous compared to drywall. Is that the main deterrent?
