1 - 4 of 4 Posts
Hi Everyone,
New to the page!
I've been interested in an IB system and I've tried modeling an IB with 2 Fi Car Audio IB18 drivers in WinISD, but I think I'm missing something.
It appears that the subs will start dropping off around 40hz. I was under the impression that IB subs would reach way down low, so I wonder if I have dome something wron in modeling them.
Suggestions as to what I might check?
Thanks!
Hi Everyone,
New to the page!
Thanks!
Hi,
sorry, I cant help you with modelling the sub, however, from personal experience, 2 Fi IB18 can get VERY low.
White Line Font Rectangle Red
Rectangle Slope Plot Font Line
Use Hornresp.net to model the enclosure.
I've been interested in an IB system and I've tried modeling an IB with 2 Fi Car Audio IB18 drivers in WinISD, but I think I'm missing something. It appears that the subs will start dropping off around 40Hz. I was under the impression that IB subs would reach way down low, so I wonder if I have dome something wrong in modeling them.
That definitely looks like something is wrong. Check that the Thiele-Small parameters that you have entered are correct.
The Fi Car Audio IB318 v2 S4 driver has Fs = 24.4Hz and Qts = 0.79. The latter is just a little bit greater than the Qts = 0.71 value needed for a maximally flat second-order Butterworth high-pass response. The driver should show as being –3dB at approximately its free air resonance frequency, Fs = 24.4Hz. The higher Qts value means that you will get a little bit of peaking in the response.
1 - 4 of 4 Posts
