You should be able to stick you sata drive in this dock and connect it to your PC externally. However, be aware that with this kind of dock the drive will stick out the top exposed. It is more intended for temporary use than long-term. That being said, it is probably more of an issue with noise and aesthetics than actual function.Hello-quick question, please...I have a spare internal WD740 SATA Raptor hard drive. I want to use an external device or enclosure to install the HD in (originally it was used w/a RAID system that went bad-I have the same hdd as my boot "C" drive internally). I see on Monoprice that they have a SATA HDD Docking Station w/ Card Reader & Hub. Can I use something like this for my internal hdd or do I need some sort of enclosure for the hdd to plug into a USB port? Also, what is a card reader used for? What is your suggestions for something like this which is an internal device being hooked up in an external device?
dalto-thank you for responding to my question. YES..., that is exactly what I am looking for! It fits my needs perfectly. I will be ordering it tonite...as soon as my wife goes to sleep :innocent:You should be able to stick you sata drive in this dock and connect it to your PC externally. However, be aware that with this kind of dock the drive will stick out the top exposed. It is more intended for temporary use than long-term. That being said, it is probably more of an issue with noise and aesthetics than actual function.
An enclosure like this is what is intended your use as a long-term solution. Heat dissipation might be an issue with a high-performance drive like your raptor.
The card readers allow you to read memory cards from a digital camera or other portable device.
