Anyone have any advice for hanging DIY acoustical panels to hollow core doors? I have 5 doors in my dedicated home theater, with two of those doors being solid core doors that are sealed well because they lead to attic space but the other 3 are interior doors that are hollow. Two of those doors are in the room (media closet and bathroom) but the entrance door also rattles with big bass hits so that will need to be addressed also. Any advise on sealing doors so that they don't rattle?
from left to right: attic, bathroom, entrance......then not in the picture, another attic and the media closet.
I was thinking that hook and loop would work well. Also removable if needed. A small piece of the loop side in between the door and the door frame worked for me. Just an idea.
Is this permanent... If so you could use some wall anchors, and some Green Glue. :T
