Hi,
REW is excellent. I have been using it on my HTPC and Macbook.
I have been using REW with a CM6206 front-end (startech ICUSBAUDIO7D). This device exhibits some DC bias in the samples on both the microphone and line inputs. If I examine the scope display and toggle the high-pass filter on and off, you can see that the filter eliminates the small DC bias in that time-trace. However, the filter appears to be located after the VU meters, so even when I enable it, the VU meters continue to display the value of the DC offset rather than the high-passed audio signal level.
Would it be possible to move the location of the high-pass function ahead of the VU meters so they are useful with a CM6206 front end?
Thanks
Web
Bear with me a few days, I'm out of the country at the moment. Will take a look at the weekend.
