OK..So I was thinking about this and wondering if anyone has done this. Having 2 sets of each speaker to get a fuller surround sound (7.1 would actually be 13.2)? Like 1 center, 2 FR, 2 FL, 2 SR, 2 SL, 2 SBR and 2 SBL. And 2 subs. I'm guessing you'd need to run multiple amps or rcvrs off each speaker. So you'd run your FR to a rcvr then run your RT and LT to the 2 FR speakers and so on. You'd need like 6 rcvrs? Does that make sense? This would be for a larger room like 12' wide by 21' long. It just seems like this set up would make a truer surround system? Or am I just way off base? :huh:
BTW..I have a projector with a 120" screen. Seating distance to the screen is 13ft.
