Any update?
What did you use to glue them??? ...you had problems just with the ports not the box, Right???I started tweakin' and playing a sound test cd when I got it tuned in pretty good, when I'll be dad gummed if the glue on the port tubes started giving way. They collapsed inward. No harm done to the drivers thank goodness. I guess I underestimated what was needed to keep them in place. The roughly 25" of 4" PVC including a 90 is pretty heavy. I'm not sure on how to secure it.
I think sonotube is the easiest way to build a sub (at least for me) ...just finished mine with 18".Well, live and learn I suppose. I'm probably going to go down and pick up material for sonotubes. I think it will be cheapest way to re-build.
Ya, no problems with the box.What did you use to glue them??? ...you had problems just with the ports not the box, Right???
Haha!Also, I have bad news for you ....after looking at the picture, you'll need bigger speakers too .
I read that epoxy is the best ... and doing what Mike suggest on post #8, and you'll be set :TWhat glue do you guys recommend?
+4 dBu Standard pro audio voltage reference level equal to 1.23 Vrms.
That is why you had to crank the levels up so much. I'm sure that this info on level differences between home and pro gear is addressed somewhere on the Shack, but as you can see from my post count I'm new and have not come across it yet. Hope this helps.-10 dBV Standard voltage reference level for consumer and some pro audio use (e.g. TASCAM), equal to 0.316 Vrms. (Tip: RCA connectors are a good indicator of units operating at -10 dBV levels.)
And maybe a bigger TV too :bigsmile: Those subs look huge next to the TV and the small speakersI have bad news for you ....after looking at the picture, you'll need bigger speakers too ... :duck: . :surrender:
Yes it has been mentioned before, if your pro-amp has RCA connectors you don't have to worry about the level inputs (that's why I got my Samson) ...if your pro-amp has just 1/4 phone or XLR you need to get a cleanbox to match the levels (here is a sample )I'm sure that this info on level differences between home and pro gear is addressed somewhere on the Shack,
You're right ...there's one cleanbox for sale now :yes: ...What I minute: audionut71 found out that audionut71 is selling that??? :scratch: . :rofl:PS you might just check out the classifieds, there are occasionally folks selling CleanBox's there.:whistling:
