Long story short (please don't ask for more right now - I am losing it after this) my dual ED 19ov.02 LLT sono build just wont work. I am not handy and made too many errors that added up and ruined the build.
I am trying to salvage it my making 2 smaller sealed sonos that I may co-locate to get more headroom or spread it they are strong enough.
I just need some numbers run to see if this is feasible and what the output would look like.
my tubes are about 24.2 internal diamater, ed's own a7s-400 is 4 cu feet and has 1300 watts. I would like to get it a bit lower into the high teens and theirs only goes to 22 pre-eq.
What do the output numbers look like for this woofer in 4'cu with 1300w?
Can a bigger enclosure let it go a bit lower or just EQ?
Is there anyway to get it to the high teens? eq2? Can an EQ2 and a reckhorn b1 be run in sequence to Dual ep2500 (the reckhorn there just to boost the signal from the reciever to the pro-amp if needed).
Finally can a standard 15amp circuit even possibly run 2 x1300w for these two and maybe a buttkicker amp as well?
