First try, I set the low cut off to off and the high cut off to the on position and set it at 50 Hz. The volume I set to about 10 O’clock position and first played a CD of songs I complied that have very low frequencies on them. I first noticed that my subwoofer didn’t seem as obvious as without the Buttkicker, yet didn’t notice anything from the transducer yet. I increased the volume to 12 O’clock position. Now I could feel that something was rattling the couch. Not sure I like this with music. I need to put a movie in with plenty of LFE.
U-571 chapter 15. Now we’re talking. I wanted more so dialed up the volume to about the 2 O’clock position. This seemed close to the right volume. War Of The Worlds has TONS of LFE, especially when the machines come up from underground. This really shook the couch. This is a sensation that is different than just a subwoofer rattling the walls and furniture. It provides more directional information, but I am not sure how. Star Wars The Phantom Menace at the pod races had the effects of side to side shake as the racing pods went from side to side of the screen. Very cool effect that I didn’t have with just the subwoofer. How does it do that with just one transducer? I guess it is the way the surround speakers combine to provide the directional input and the transducer adds the tactile sensation.
Black Hawk Down it felt as if I could feel the downwash of the chopper blades as they passed over head. It was a very real and being there sensation. I am not clear how it does this but it is impressive and involving. Once you get the settings to match up with your surround speakers, it is just amazing how much this adds to the overall experience.
I have now mounted the transducer directly to the couch by first mounting it onto a 2”X6” pressure treated pine board. I used ¼” X2 1/2” bolts with washers and ¼” nuts. I drilled four holes into the angle iron couch foundation and used ¼” X 2” bolts with lock washer/washer and ¼” nuts. This seemed very solid and should transfer the vibrations more consistently throughout the couch.
