Hi all
I have built a cheapo sub with jaycar 350w amp, got my brother to build a steal enclosure for it in pics and the venom 15" running in a 500mm by 400mm by 450mm ported enclosure, 75mm port which is 350mm long. It was meant to be in the room hence my box limitations in size
It sits in a back room behind my tv and is able to generate very deep bass, must be due to the small room acting like a bandpass enclosure. The room has a door on it which opens into the sliding door which is a pain as i have to keep open
However it is really peaky around the low stuff and muddy
i remember a while back being told to take out the 35hz booster in the jaycar amp. I wanted to clarify how much benefit i would get from this before i bug one of my sparky mates
Would also like to start looking at a new driver and box config, any suggestions, still in the cheaper range. i would ideally like to keep the jaycr amp to limit cost. After something musical also and i do like the sound of the 15s
