1 - 9 of 9 Posts
My speakers are not a full DIY speaker from the ground up, but rather a rebuild of a pair of 1979 Altec Lansing Model 15s (2-way, 802-8D compression driver in bent horn, 12" woofer re-conned by Altec in 1991).
I rebuilt the crossover using Solen Fast Caps, rewired the speakers w/ Kimber 4TC, replaced cheap original speaker binding posts with HD gold plated brass 5-way, and refinished the cabinets to like new condition with a warmer stain.
*Attached are photos of the sanded M-15 cabinet, finished Altecs in the system, crossover rebuild (before I changed my mind and redid the Audioquest wire (shown) with Kimber 4TC), and new binding posts.
Nice work.
What's the function of the original knobs, and did you maintain their utility after the rebuild?
The controls are the HF and MF trim pots on the horn to be able to balance it to the woofer. The woofer runs full range w/o a crossover network. There was no problem with the pots but I cleaned them with contact cleaner to be safe. I could have removed them and substituted a resistor of the value of the optimum position marked by Altec, but I like the ability to tweak the speakers a little depending on the room and amplification.
Very nice! Any 'before' pics?
Very nice work, I have a old pair of Altec model 19's, I still love the sound. It may be time for me to re build them.
Gregg
Gregg,
As you probably know your Model 19s are a step up from my Model 15s. They use the same HF compression driver in a different horn, and more importantly a 15" woofer and xover. If you don't want to put the time and effort into refinishing the cabinets, at least replace the caps in the xover w/ Solen. Though inexpensive they are an excellent match for Altecs. I'd rewire the speakers w/ modern OFC copper. These differences noticeably raised the performance of my speakers.
NPE caps do indeed age over time and use, so that's definitely a good approach for a refresh. The modern fancy "audio grade" capacitors, like poly and film & foil caps, should last forever since their electrolyte won't dry up.
Beautiful work! I remember in the 70s when I was in the Navy, every disco or club from Taiwan to The Philippines to Japan used those speakers. Man could they play loud and clean. I always wanted a pair.
Thanks Soup for your compliment. Yes these are the clearest speakers I've owned. Watching a movie with these offers dialogue so clear and intelligible, and music is pure, clean and musical.
1 - 9 of 9 Posts
