1 - 20 of 25 Posts
HTS Moderator , Reviewer
Yes those are the the DIYSG 1099 Kits...
I've had a chance to hear them. you should be WELL pleased. I'm using a set of speakers from Eric myself. the Cheap Thrills monstrosities. I really want to build a set of 1099 or Cinema 10 max's myself.
Cant wait to listen to them. I will finish them with flat black Laminate from Wilson Art. I will spray the front with enamel. I have the laminate ordered. I do not have time to properly bondo the seams and sand, bondo, sand, bondo , sand etc etc... and it would bother me!
Well I have ordered and received my Flat black Laminate. I have 2 large sheets. I have never used this so I hope it comes out okay. I am spraying the front with flat black enamel. This is only the first coat. I just did a nice 1500 grit sand paper on them and then will apply 2nd coat. Maybe a 3rd.
Discussion Starter · #15 ·
coming along. putting laminate on. wish i would have decided to do laminate on the front baffle. its much easier than trying to spray and sand 7 coats only to find an imperfection here and there. using the Bosch palm router with a Bosch 2 flute flush cut bit is working well. i will do laminate on my subs for sure.
i spent about a week or 2 spraying the baffle and think i should have not done that first as its probably better to do the laminate first then spray if you are going to go that route. also i did a 50/50 mix on the cabinets and I am not sure that is necessary if you laminate because the contact cement must seal them pretty well.
these boxes are also heavy to be moving around...im telling you... working on five is also a lot of work.
1 - 20 of 25 Posts
