1 - 5 of 5 Posts
hi,
just got electrical calibration file,and could anyone help to check if i need to do any re-formatting
in order to load it into REW for using?
here is some lines in the tXT file:
"Transfer Function Mag - dB volts/volts (0.10 oct)(eq)(eq:aux)"
"Hz" "Data"
770.9704, -0.4891936
822.3684, -0.5123992
873.7665, -0.5353142
thanks in advance!
jianhua1975 said:
just got electrical calibration file,and could anyone help to check if i need to do any re-formatting in order to load it into REW for using?
JohnM said:
You can use space, tab or comma to separate the values on each line, the data you posted loaded fine when I tried it - REW puts up an error message if it has a problem with the data. Note that the cal file in the Mic/Meter preferences is only used for new measurements, to change the cal data for an existing measurement click the "Change Cal..." button at the bottom of the panel for the measurement.
> I would simply try loading that file to see what happens .
> You may find that you need to delete all the extra text not related to the actual data .
:sn:
1 - 5 of 5 Posts
