1 - 5 of 5 Posts
Super Moderator
Welcome to HTS!
It looks like your bass response falls off quickly below 200Hz. What are you using to measure? Have you created a soundcard calibration?
Posting graphs is best if you attach the images directly to the post in the "Additional Options" section.
Discussion Starter #4
the soundcard is a realtek, also the microphone used Is a Sony fv5 and the graphic were the standard one,i did calibration to microphone before of run re also perhaps the room havelot of absorbing material,also for avoid the measurement contamination turned off the subwoofer and set in large the front speaker
1 - 5 of 5 Posts
