Just glued on the front baffle. It's the last piece of the puzzle. I almost screwed up everything at the end. I was using an electric plane to level the front before I glued on the baffle. Well I got too close to the edge and blew out a big chunk of MDF. I'm attempting to glue the layers back on. (that's why there are 3 clamps going across the bottom.) I hope it works out OK. It really isn't that big of a deal since the sub will be hidden behind the screen, but I wanted it to look presentable. Again this thing is a bear to move around. I'm guessing once the driver is in, the final weight will be around 175-200lbs.
