21 - 28 of 28 Posts
Discussion Starter #22
Hi,
I've loaded a house curve with a 6 Db. raise at 20 Hz. and 0 at 80 Hz.
I've made measurements without EQ and let REW assign filters.
It's telling me to use 2 12Db. boosts on the behringer... Isn't that a bit much?. I remember that in the past people said never to boost more than 5 Db. on the behringer...
Dimitri.
Super Moderator
Thanks. Looks like your fine. There are plenty of severe cuts to go along with the boosts. Actually, that can be just as bad a severe boosts, because severe cuts leave severe peaks between them.
Re the boost at 77 Hz: If that filter did not eliminate the depression, then you should remove it. That one looks like it might be a null.
Discussion Starter #26
Hi,
I've added a picture of the response that I now have.
Sounds a lot better this way with way more transparent sub sound. I could use a little bit more "slam" though. It sounds very balanced, but a bit more punch would be nice. Maybe boost the lower end a bit?...
I'm also thinking about a bigger center speaker to match the Q11's. Something like the KEF bIQ6 C. Would youi guys say that's a major upgrade from the Egg?...
Thanks,
Dimitri.
Super Moderator
Maybe try a steeper house curve...
Yes, I think the bigger speaker would sound much better.
21 - 28 of 28 Posts
