Hey guys, so I'm kinda new to this whole home theater world and just recently set up my system. My receiver (Pioneer VSX-818V-K) displays "OVERLOAD" when it plays louder than around -30dB for a couple hours, and it precedes to shut off. It's also fairly hot when this happens.
My questions: Do i need a new receiver? Would an amp be worth it for the SQ? Or, could I find a good enough way to keep it cool? How do YOU keep your receiver cool when you're jamming out?
Currently, the receiver is powering 120W x5 channels to Klipsch B-3 mains, a C-3 Center, S-1 surrounds. I also have a a Polk PSW10 hooked up (which has its own 50W amp). The receiver sits on a shelf which isn't enclosed and has plenty of room to breathe. It needs to be ready to play hours of music at loud volumes:bigsmile:
Thanks in advance for any input!
-emak
You could try blowing out all the dust inside the receiver with a can of compressed air. Too much dust can cause all sorts of issues.
I had that problem with my VSX-81txv and I did a reset and it fixed the problem. If you do a reset just remember your settings for imputs and such so you can set it back up correctly.
Has it always done this, or just started recently? Has anything changed in your system?
Thanks for the fast responses everyone.
eugo: I've owned the receiver for almost 3 months now and it hadn't overloaded until mid-January when I bought S-1 surrounds and the PSW-10 sub. I have not yet put the receiver to the test with full 5.1; I generally play music in 2.1. Since I didn't have this overload problem when i was playing music in 2.0 last year, it's making me think the sub is causing too much heat... Any thoughts?
tony: I'll have to go buy a spray, good idea though.
tcarcio: Thanks, i'll reset and test it out this weekend when my apartment neighbors are a bit more lenient to the noise :T.
It takes a while before the receiver overheats (@ -20 to -30 dB). Does anyone think that the receiver is overloading simply because the music is too loud? If so, what are some good receivers in the 300$ pricerange that I should consider upgrading to?
I doubt it, make sure that you dont have any of the strands of speaker wire touching each other where you connect to the terminals on both ends. Running a level of -20db should not be that loud, does the receiver have some sort of auto room calibration setup with a mic? if so I would run it again. Make sure that your master ohm setting is set to 8ohms as I believe that your speakers are 8ohms.
