An ATMOS track is not LPCM, so it is not compatible with the miniDSP nanoAVR HD, and there is no way to make them work together.
Yes.
An ATMOS track is not LPCM, so it is not compatible with the miniDSP nanoAVR HD, and there is no way to make them work together.I've been looking at moving to an Atmos setup, but was wondering how that would work out with the nanoAVR HD, since it can only handle 8 channels and I would be running 10 channels (9.1 setup). I haven't actually implemented the nanoAVR HD in my system yet, though I already purchased it, and the thought of using an Atmos system is intriguing to me especially because I am close to wrapping up a new HT room. I guess the real question is can the "Atmos" track be sent uncompressed via linear PCM, or is it hard coded to the Dolby Atmos format?
Yes.Edit: or I can just use my minidsp 2x4 for my subs and pick up a denon 4250 or something like that with atmos, xt32, and analog out.
Just when you thought you were safe from Lou... :rolleyesno: And I was just about to start a new thread to ask a similar question (I'm interested in adding a miniDSP to pre-EQ my sub).I believe most users would pre-EQ the sub with the miniDSP, then run XT32. I am not sure how much difference it makes.
Yes.Are you saying that you're not sure how much difference it makes to perform the miniDSP calibration before XT32 as opposed to after XT32?
